Thanks for replying.
I was thinking that "layer height" was somewhat "fixed" by predefined settings, next time I will tune the layer height as you said. It seems the most effective solution to now.
I had understand your solution, it is feasible but it seems more an hacking than a final solution. As you had pointed out, printing another layer would be a more elegant solution.
Edited by Fabiuz
GregValiant 148
The layer height may be input at 3 decimal places. In your example, if the layer height was .143 and Initial Layer Height was .142 you would (theoretically) end up at exactly 1.00.
BUT...If that block had a step at .5, then the step would end up at .428.
I don't know the Ultimaker machines so this next refers to my Creality machine.
Given the 1mm tall block and all layer heights at .15 then at the start of the top layer I could change the Home Offset Z with an "M206 Z-0.1". The result would be to fool the printer into moving the last layer up an additional 0.1mm. But all the E numbers for the top layer were calculated at a Layer Height of .15 which I have effectively turned into .25 and so the flow is wrong. An M226 S166 would be required to adjust the flow to compensate. That's a lot of Flow for my hot end. It might be necessary to reduce the speed as well so M225 S33 to drop the speed by about the same amount as I increased the flow. At the end of the Gcode file I would need to straighten all that out setting the Home Offset, Flow and Speed back to the defaults. It would certainly be easier if Cura could admit that it needs another layer of 0.1 height to complete the print.
But what if the step was the important feature and needed to be an exact height? What if I had a 40mm tall part with 10 steps of varying height that were all important?
"Everything effects everything" and taking the human mind out of the loop and letting the software decide what's important isn't ready for prime time yet.
