You cannot modify the generic profile that come with Cura, but just click on Duplicate and then you should be able to change the temperature.
Where is duplicate. thanks
Thanks that totally worked. By the way if anyone else does this click activate I am pretty sure It did not set it right away.
Smithy 1,146
The print temperature is in the material profile, so take a look there and change the temp you need for the material you use.
