TweakAtZ
simon
Hi, does any one have a working version of Tweak at Z for the latest version of Cura. I managed to modify Bedtempatz so that is works but TweakAtZ is beyond me at the moment. I'm after version 3.0 which has bed temp control as well.
https://github.com/D...TweakAtZ.3.0.py
In the version I tried to modify, I just could get it to add anything to the gCode.
Any help would be greatly appreciated.
    Hi, I was wondering if there's a trick to getting the plugins to show up in Cura at all. I use an iMac and when I go to the plugins menu in Cura (13.12) and click on "Open plugins location" and try to select a folder with my plugins, nothing gets selected. Thanks in advance for the help!
    Did you put the plugin here?:
    ~/.cura/plugins/
    More here:
    https://github.com/daid/Cura/issues/602
