Splash screen doesn't show any options to continue/dismiss
zetacu
Posted · Splash screen doesn't show any options to continue/dismiss
I recently installed Cura on my laptop on a Manjaro/5.4 LTS, on KDE 5.20, I installed Cura from the official repositories and for some reason on the welcome page I can't select/click anything, therefore unable to continue and use the program. I have tried to click everywhere, restarting the app and the computer, full clean install. Is there a way to see the logs for search the error (if any), or a way to dismiss the modal by creating a conf file somewhere.
    Use the official AppImage instead of the package you use now. There is an incompatibility between Cura and the version of Qt on your system. The AppImage comes with a version of Qt that works.
    • Thanks 1
