How do I make a new default material?
AliRassi
Posted · How do I make a new default material?
my initial guess was that you define your default material somewhere in the machine configuration files (Cura profiles!)
so I looked and found :
        "preferred_material": "generic_pla",
I changed its value to "generic_abs" hoping it would change my default material but nothings happens!
the new material name also matches the name of its file in "materials" folder in "resources"!
and I also checked and it's not in the excluded materials in the definition file!
any thoughts?
    I couldn't reproduce this. I did the following:
    1. Change "preferred_material"  to "generic_abs"
    2. Start up cura
    3. Add the machine that i just changed the prefered material of.
    It showed generic abs as expected.
    Oh yeah!
    it only works when you add your printer once you have changed the definition file!
    I was hoping to see the changes being applied after having a printer set up (for example how it updates the variants_name or has_materials)
    thanks for clarifying!
