10 hours ago, Labern said:Hi. This was a common issue and you can just put a slight bend in the tongue of the micro switch so it clicks before the fan shroud hits the side of the machine.
Thanks for the reply. That was my next strategy. Or maybe add a little something on the block that hits the limit switch. When you say it was a common issue, do you know why? I've found another thread about someone with a fan bent outwards that had the same problem (but that's not the case for me). My initial thought was that it had to do that I've changed something in the axles alingment, but the more I think about it, the lesser it makes sense. In fact, my real initial thought was that the + print head was wider than the UM2, but it doesn't seem to be the case.
I'd like to understand, as the upgrade kit is new, and the machine is "like new".
Cheers!
Labern 775
