Ultimater 3 - Y axis motion is choppy. Need help fixing.
Posted
· Ultimater 3 - Y axis motion is choppy. Need help fixing.
you seem to be on the right way.
When I read you changed the print head revovering a head flood, I remembered an issue I had when reseating the print head cable some time ago (ic20-error). After retighening the four long print head screws, the movement on Y-direction was also choppy. SLIGHTLY loosen the four long screws (just releasing torque a bit) solved it for me, so I suppose some interference with the linear bearing inside the print head.
Maybe it helps for you.
Regards
We don't often release an alpha version of Ultimaker Cura... So what's different this time? This Alpha contains such a huge slicing engine overhaul that we really need your help!
We wish to celebrate and honor the innovators that push forward the field, technology and world. We opted to not present it as a competition or ranked list. Every innovator has earned his spot on that list in their own way. We also look at the 3D printing industry as a whole and not limit the list to those only using Ultimaker.
Enigma_M4 47
Regards
