My stipid issues
geeks
Posted · My stipid issues
Before you break everything. I noticed in the menu that it was possible to change materials. From white to orange PLA. :cool:
Is this button on the machine that I must use? :oops:
What advice would you give me to do this task without difficulty?
I noticed on the X axis of the head a little iron filings! Is this normal or not? :eek: :shock: :roll:
For now it will be all. The printer works. :wink:
Thank you very much.
    Ok!
    Regarding filament, I think I used this menu.
    IMG 3557
    On iron filings, this is a picture that should speak volumes.
    IMG 3556
    I hope I will not have trouble with this story of iron filings ... :oops:
    At the next service, I spend a cloth. I'll show you exactly what it is.
    I still have a little oil for weapons. I put a drop on the axes.
    However, I think procure me oil sewing machine.
    ndeed! It is dust ;)
    I was afraid for a moment.
    The addition of oil for weapon did not problem to the axes. I'll see if I have to go the new oil.
    With that, I run a print 4H. This is the greatest time of print since UM2. :cool:
    When I click your images to get a closer look I get "you do not have permission to view these images".
    I assume the moderators can see them. Is this my settings or Geeks?
    Oups, sorrry :oops: :oops:
    Normally, I solved the problem.
    Thank you for having warned me.
        • 6 replies
