GregValiant 1,251
The error message pretty much says it all. When you load a gcode file it can't be modified. You can change it in a text editor. Cura can interpret a Gcode file into a cartoon for the Preview pane but that's it.
Â
"this happens once i load an image in to write from g code in order to put into labista"
I'm sorry. You'll have to explain more because I have no idea what that means.
darksteve1985 0
