Why is (nearly) everything 0,2 mm even though I assigned 0,16 mm ?
Ray_McRay
Posted · Why is (nearly) everything 0,2 mm even though I assigned 0,16 mm ?
See Screenshot.
Is there something like "automatic Layer height correction"? How can I turn it off?
P.S.: I am aware that a 0,16 mm is not necessary for this specific part. This is a Test part.
    Posted (edited) · Why is (nearly) everything 0,2 mm even though I assigned 0,16 mm ?
    4 minutes ago, Smithy said:
    Have you maybe enabled Adaptive Layers?
    Yes! This was it! Thank you.
    This option really should show when you type in "height" in the search bar...
    Edit: It does. Facepalm.
    Edited by Ray_McRay
