Thanks for your reply. I am located in Texas. I checked your website and saw that you have a replacement lift assembly. I will make sure to check the site often to see when it is back in stock.
fbrc8-erin 235
1 hour ago, gibso10 said:Thanks for your reply. I am located in Texas. I checked your website and saw that you have a replacement lift assembly. I will make sure to check the site often to see when it is back in stock.
If you put your email address in above the green button on the product page, you'll automatically receive an email as soon as it's back in stock.
fbrc8-erin 235
Where are you located? These are out of stock, but should be back in soon if you're in the US.
