Air Manager Installation Issues
boundaryllc
Posted · Air Manager Installation Issues
Hello,
I'm having a problem with the air manager installation. I've installed it as directed with the correct plug. I've also tried using both plugs in the back of the fan. None of this causes the air manager to be recognized. After you click install air manager and the machine reboots, it always says air manager is not detected or was uninstalled.
Printer has the latest firmware.
I've checked all connections and they are correct
What am I missing???
Thanks,
Travis
