You can improve it a little with settings, particularly slow or switch off the fan, but the only real answer to this is a heated chamber.
Try wrapping your UM in bubble wrap or towels as a test, often this is enough just to retain some of the heat bed energy.
simon 1
Have you tried the default UM2 ABS settings.
Bed 90
Fan 50
Printer head 260
Flow rate 107%
Try print speed 30mm/s
I printed a tall thin ABS part today with those settings. I did have a bit of delamination, but nothing like that. I'm still working on settings but something around those values may work better.
