Infill in embedded holes
ONEinsanePHReaK
Posted · Infill in embedded holes
The "bugs" are probably in the stl file.
Here are all mesh errors marked with a pin (you can check it with Meshmixer).
It seems like there are already "magnets" positioned in each hole. There's the "puck" (with 6 holes) and 6 "magnets" in the file - (overlapping the holes) - 13 distinct shells in sum. So... remove all the extra geometry and it should slice fine with Cura:
Puck_with_magnet_holes.stl
Good luck!
