tinkergnome 929
On 12/26/2020 at 3:59 AM, 3DOKIE said:When file is saved in .gcode, the M140,M190 codes are not generated for the Build plate heater.
That's a file for an Ultimaker S5 (with GCode-Flavor "Griffin").
The buildplate temperature is set in the header section (the comments at the beginning of the file). That's all the printer needs to know.
Why do think it's a bug?
1
DivingDuck 105
Maybe you need to check your printer setup in Cura. -->Preferences -->Printers -->Machine Settings -->Heated Bed
