Thank you GregValiant. I do not know how I enabled that as I am looking now in Cura and it is unchecked. I normally select New Project as I flip back and forth between my CR-6 SE and CR-6 Max and like to have the settings wiped clean each time.
And after staring at the G-code for long enough, I see on those few layers where I didn't see an initial Z height change, that it was there a few lines above.
I do need to find why it is driving the head down into the model though. I haven't found where in the file that happens or if my printer is having a brain fart at that point. Although with this print file, it reproduced it twice. May try again and watch it when it does it since I know the approx point it happens, maybe I can watch the layer count.
GregValiant 1,321
There are no Z moves in that file larger than your Z-hop height of .2mm. Whenever it goes up .2mm for a Z-hop, it comes back down .2mm to the working height.
According to the settings listed at the end of the gcode file, Adaptive Layers is turned on.
[metadata]
position=0
type=quality_changes
quality_type=adaptive
setting_version=16
Varying the layer heights to the model geometry is what Adaptive Layers is supposed to do.
