GregValiant 159
2 hours ago, shoe said:"When is the retraction an issue? During printing Infill?"
Not retraction itself - the number of retractions in a small area can cause a lot of unnecessary movement, especially if z-hops are enabled. The printer would be constantly retracting and priming and jumping up and down, as opposed to just moving to the start of the next extrusion.
"Why is increasing the multiplier better then increasing the infill density?"
They work together. The multiplier gives thicker internal walls. The density increases the number of walls, but they are thin and weak. As the density approaches 100% the fact that the walls are thin becomes less important since they get very close together. At lower densities and a higher multiplier, your internal grid is spread out but each internal wall is a rib (or gusset if you prefer) in it's own right. It's a question of balance.
"In tension?" What do you mean? Isn't driving a car over a block something like "tension"?
Driving a car over a print is compression. Consider that concrete is excellent in compression, but if you grab both ends of a concrete tube and pull on it, it will come apart pretty easily because it is poor in tension. They might make roads out of concrete, but you would never want to make the cables of a suspension bridge out of concrete. You can do things (like you are) and adjust the internal structure to increase compression strength. When it comes to tensile strength, you are pretty much stuck with layer adhesion as a limit.
"Did you ever experiment with "overlap"? For example "infill overlap"?"
If you have a print of 3 walls or less, infill with a high overlap can leave artifacts (marks) on the outside of the print. This is more noticeable at high speed as there is going to be some wobble in the print head as it stops to make a turn.
"...Things like a slightly blocked nozzle..."
That's a printer / maintenance problem. Increasing the nozzle size to a .5 or .6 can alleviate the problem. They just don't clog as easy. The price is that the prints aren't as "crisp" and details can disappear. Moving down to a .2 will increase the likelihood of a clog, but the prints are "sharp" and details better defined.
1
GregValiant 159
"I am confused."
Welcome to the club.
I like to use Grid as it gives strength in all three axis. With the Infill Density at 15% set "Infill Line Multiplier" to 3. You will want to play with the infill type and the line multiplier to see what works best for a particular model. I also increase my "Retraction Minimum Travel" to a number (15?) that keeps retractions down. That keeps the number of z-hops down and can decrease printing time. Lots of infill means a slow print.
Walls 2.0 thick and Top/Bottom 2.0 thick. With the Grid infill at 15% and multiplier at 3 you can drive a car over a printed block. In tension? Now that is a whole nother story.
Edited by GregValiantLink to post
shoe 0
Very detrimental to a prints "sturdiness" is how much print elements "overlap". Not only within a layer, but also between layers. Things like a slightly blocked nozzle (you wouldn't probably notice if it is not extremely blocked) can lead to much worse overlap. Especially between layers. In an extreme case you notice, because a print only have 50% of its calculated weight. But something like 10% you wouldn't notice.
Edited by shoeLink to post
