GregValiant 159
I think what is happening is that Cura is calculating based on 2 wall loops, and there is no "Top" or "Bottom" in that area. If I change it to a single wall, then the top and bottom show up and the upper portion is supported with a regular interface.
So yes on using the support blocker to modify that joint with 100% infill (or more walls).
Would it be possible to add a chamfer at that joint? Even a small chamfer is better than none and would cause more plastic to be put in the joint. You would still need the support blocker though.
obewan 12
One way is use the support blocker tool and make the joint 100% infill
