Slicing Issue with Cura 13.12
doktrmike
Posted · Slicing Issue with Cura 13.12
I want to print this Lego to GoPro mount:
http://www.thingiverse.com/thing:13518
However, Cura is slicing in such a way as to disconnect the two areas of the pieces. You can see it clearly using the Layers view in Cura; there's a big gap between the Lego mounting area and the GoPro mounting area.
Can anyone suggest a workaround?
Thanks,
Mike
    In Cura, 'Expert' -> 'Open Expert Settings...', try turning on 'Combine Everything (Type A)'. If that doesn't work, try the other options.
    I didn't try slicing it, but I suspect the two parts aren't properly unioned together in the STL file, but rather exist as two separate intersecting objects. That confuses the slicers, as they (correctly) assume that the bit that is inside two separate walls should be considered to be on the outside of the shape. The various 'Fix Horrible' settings try to work around those issues.
    There are 11 combinations of using those checkboxes. Try all 11 before giving up. Usually one will work. Checking both "a" and "b" - don't do that as that is identical to checking only "b" (or only "a" - I forget - just don't check both).
    If none of that works you can try editing it using this procedure (meshlab is free):
    http://meshlabstuff.blogspot.com/2009/04/how-to-remove-internal-faces-with.html
