Stupid enough I did not think about simply cutting out that piece in my model.
After printing the piece i simply though i have to get rid of that top layer going straight into settings. Cutting it out in the model will actually be a better solution.
Thanks!
GregValiant 1,321
So you want the walls to print so you have edges to use as a dam for the plastic? I think you'll have to go in and modify the gcode. Cura puts comments into the gcode when it changes "types". Going through the last layer gcode and deleting everything that is "type:skin" should work. You could test that on a calibration cube. Make the cube 2mm tall in Cura and then alter the gcode and delete the "skin" of the top layer. That wouldn't take but a few minutes to alter and to print.
Your alternative would be to make a cut in the top surface of the model so you end up with a pocket with walls around it.
Edited by GregValiantLink to post
