Thanks @GregValiant for the reply. If it was a clog it would not be so uniformed perfectly to that layer. It appears to be a fill issue where it looks like its inserting a break / join line.
Will research "extruder missing" as I am not familiar with that.
Cheers.
GregValiant 1,305
Zooming in it looks like it may be intermittent under-extrusion. You might be getting a partial clog in the nozzle and then it clears itself. It's hard to tell but is the very top layer rough on the outside edge (looks like there are little points all around)?
Have you heard the extruder missing steps?
