I designed an adjustable shelf to go on top of a TV or Monitor.
FraggleRock
Posted (edited) · I designed an adjustable shelf to go on top of a TV or Monitor.
This has rotating arms that can be adjusted to stand against different TV or Monitor thickness while keeping the shelf horizontal.
I made this cause I had no high place around the TV to put my router so top of the TV sounded like an ideal solution.
If you find this design useful, you can download it from Thingiverse.
Edited by FraggleRock
  • Like 2
  • 1 month later...
