Posted
· Third party 3D printer not centered in the hotbed
Go to left side of screen in PREPARE mode. Click on your printer, then do "manage printers" then "machine settings", Uncheck "origin at center" (it's almost certainly already unchecked). Then check the dimensions of your bed - for example, if it says your bed is 200mm wide but it is actually 100mm wide then it will be printing on the right half of your print bed.
I'm guessing you have the wrong dimensions. If this isn't the issue then please show a 5 second video of the problem and also show a screen shot of your part after you slice it in PREVIEW mode showing where the part is on the bed there.
gr5 2,224
