Material station humidity control problem
Leandrokoser
Posted · Material station humidity control problem
Hi people!
We recenttly bought an S5 Pro Bundel and we are facing seriuos problems.
I am in a city that the humidity usually reaches 85% on the summer ( south Brazil ).
The printer is installed in a room with air conditioning ( 65% humidity in the room)
The Material station (MS) is never turned off, and I only use original Ultimaker materials.
I only open the MS when some spool finish, and is very quickly.
My PVA, Nylon, TPU printing are horrible, I need to keep dry in an external device and keep on MS when printing.
I'm dealing with my local supplier since 16/december.
Do you guys have this problem too? What procedures can I do?
    • 2 weeks later...
    Hi I had the same problem after 2 months of using the Pro Bundle. After contacting my dealer, Ultimaker offered me an exchange of the dehumidification module which solved my problem. (60% inside before, 20% after). Contact your dealer and keep us informed.
    • 1 month later...
    Ultimaker offered to my dealer to change the module, but not for free.
    As it´'s expensive to buy this every 4/2 months, we are looking for a DIY solution.
    Please @Silfried tell me if the change of the module is ok until now and how many time is working after this repair.
