Breakaway clogging Issues
RickyDRZ
Posted · Breakaway clogging Issues
Good afternoon,
Hello to everybody!
I'm writting here because the last few days I've been having a lot of issues with breakaway clogging. I was printing a part that lasted 3 days and when it had printed pretty well for one and a half days the breakaway got clogged.
I did the atomic clean up, everything seemed to work fine, but two hours latter the printcore got clogged again.
I've tried many things, cleaning, changing parameters in cura, changing the spool to another location, ... but any of them worked. I finally changed the printcore to another one that was working fine, and it got clogged too. So as a last try out I opened a brand new spool of breakaway, I putted it on the same printcore and now is working just fine!!
And the my question is!: If I am using a Polybox with temperature around 22ºC and humidity between 10-20%, and I haven't touched the box since I opened the spool, the other spool that I have inside the box is Tough PLA and is working just fine. Why is breakaway just not working when I still have half of the spool to go. It worked fine for the first half and now it's impossible to work with!! I would understand that if I had the material just on the back on the printer could have got some humidity or dust, but having everything under a controled environment? Could it be that the breakaway got too dry?
If anyone has had the same issues and could share...
Thank you all very much,
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 14 replies
