1 minute ago, gr5 said:Yes! The feature is called "skin expand distance". If you set it to 100 for example it will completely close those or you can set it to say 4mm and it will give much stronger attachment between top skin and walls sitting above.
Thank you very much, i will give it a try this evening. ☺️
gr5 2,332
