Layer height was .2mm
Using the default Cura slicer.
Spiralize is NOT enabled
Tension wheel is not deformed, I actually switched to the new one I got with my dual extrusion kit, same results.
I'll try without fan and minimum layer time to 7.5s and see what I get.
I'll update when finished.
Thanks!
illuminarti 18
What layer height and wall thickness are you printing at?
What Slicer?
Are those printed with Spiralize turned on in Cura?
Have you checked that the tension wheel in the extruder body isn't deformed, and turns freely?
Try printing without the fan, and see if that makes a difference (but set minimum layer time in your slicer to 7.5s first).
