Cura slices only one layer
BensonFilmworks
Posted · Cura slices only one layer
Hello friends,
I'm trying to print the spring for the butterfly box for my granddaughter's birthday.  https://www.thingiverse.com/thing:2977908
The instructions indicate that the walls are only one shell thick.
Cura spits out only one layer.
The details:
Cura 4.8.0
Windows 10
GCode and .3mf Files attached.
Thank you in advance for your help.
Best,
Dan
SBFB-SPRING.gcode SBFB-SPRING.3mf
    Posted (edited) · Cura slices only one layer
    Not sure what's causing your issue as loading the .3mf is fine in my slicer.
    In case you don't figure out what's wrong in time, here's the sliced file with the settings you had in the .3mf for a CR-10S. This is for a 0.4 mm nozzle, PLA print by the way.
    CE3_SBFB-SPRING.gcode
    Edited by juspch
    Thank you for your time and help.  The g-code printed just fine.
    Somehow loading the .3mf into my cura slicer still produced the same result of one layer sliced.
    However, since I was able to print my part I'm going to table this mystery for now.
    Again, thank you for your help.
    Dan
        • 1 reply
