It would help if you opened an issue at https://github.com/ultimaker/cura/issues
Hi @ahoeben Thank you!
Hi @nallath Hope the team can fix the inconsitent behavior of openning STL files. Thank you!
Existing models are lost:
- click/open an STL file
- commandl line "cura.exe aaa.stl"
Existing models are kept:
- menu/open an STL file
- drag/drop an STL file in Cura window
On 2/8/2021 at 5:04 PM, curasurf said:Existing models are lost:
The issue makes it impossible to ADD a solid model from a modelling software directly to Cura.
I believe that the team should have noticed this. Hope it could be fixed. Thank you!
1 hour ago, curasurf said:I believe that the team should have noticed this. Hope it could be fixed. Thank you!
1
1
- 1 month later...
I have created a PR here: https://github.com/Ultimaker/Cura/pull/9437
ahoeben 1,965
That should do it, but I can confirm that the behavior is not what I would expect. I would swear that previously the behavior was that a new project were added to the current project. Otherwise the "single instance" feature is quite useless.
curasurf 4
@ahoeben Thank you for your comments! It would be great if the behavior can be brought back.
