Posted
· Wrong Scale on Z axis after firmware update
Sounds as if the number of steps per mm is wrong in the firmware. I guess, you compiled your own version of Marlin or built it at marlinbuilder.robotfuzz.com? If it's the second, check the number there; it should be 8/3*200=533.33333 (as long as you use the standard z thread and motor). If you have an Ulticontroller, you can check there.
EDIT: You can also use the M92 code in your start.gcode (UM1, correct?)
Dim3nsioneer 557
