Ultimaker S5 Filament won't unload
zeeg617
Posted (edited) · Ultimaker S5 Filament won't unload
I have a critical issue with filament.
Issue: PLA Filament does not unload when press the unload button, motor sound was normal, but the filament did not move.
Observation:  I heated the nozzle to 220 degree, then I lifted the lever on decoupler and tried to pull the filament out manually, but it is not moving. I opened the cover of the decoupler. I tried to pull the filament by hand again, it seemed I was not pulling the filament but the tube, the inside of the decoupler looks fine, nothing is stuck in there.
I tried to choose the load filament option but does not see any extrusions.
Suggestions?  I want to hear some expert opinion before I forcefully remove the printer core and cause damage to the printer. Thanks.
Edited by zeeg617
