So the idea would basically be that when switching nozzles/colors for a dual extrusion print, instead of printing out a big tower you could instead used that purged filament to create another model. Setting a model to a prime tower would set it so it prints first (as to work properly as something to purge filament) and it would print upwards.
The features I'm referring to are implemented in PrusaSlicer as MMU2 compatible features.
I apologize if I'm not doing a very good job at explaining this. But the PrusaSlicer features are pretty much what I'm referring to.
nallath 878
So what would marking one model as a prime tower change versus not marking it at all?
The Outer wall Wipe Distance or Infill Wall wipe distance might be what you are looking for.
