Try lowering the printing speed.
Have you also tried changing the "print speed" parameter of the postprocessing script?
You'll probably get a more informed answer from Zonestar instead of the Ultimaker forum.
Try asking your question here:
GregValiant 1,319
Layer shifts are commonly caused by loose belts. You have a lot of belts on that machine. When you say you already tried lowering the print speed - from what number to what number? What speeds did you try?
You might also try lowering the Accel and Jerk settings to soften the starts and stops. With Accel at 200, Jerk at 5, it will be slow, but it should provide a starting point and you can increase them until the layer shift shows up and then back them down.
As Ahoeben suggests, it's likely a machine problem so the manufacturer is the place to start.
kripi100 0
sorry that my wrote is looking like that i just used translate. i am not 100 percent knows english so i used translate. if someone knows how to fix my printers problem please tell me. (i am pretty new to that stuff and im not sure if the problem is in the cura or not i just wanted to ask in a big forum.
