thanks for the reply,
when I did this manually it allowed me to set it up but after the test extrusion, the only option available is to change the material. so its as if it still doesn't recognise what it is.
It won't let me carry on with set up without changing, which then means removing it and im now back to the start again.
gr5 1,605
To manually select just scroll through the choices until you find tough PLA. Tap it once and then tap the blue "confirm" button.
To get to the choices you click on the left/center menu. Then in upper left (if left core) click the material and then in the upper right click the "..." and select the material there.
