Unable to progress past the welcome setup on new install?
Posted
· Unable to progress past the welcome setup on new install?
This can be fixed by using the AppImage provided by Ultimaker instead of the version provided by Arch. The latter is not maintained or supported by Ultimaker. The issue is that Cura 4.8 is not compatible with the version of Qt installed on your system. The AppImage includes known to work versions of the dependencies of Cura.
The next version of Cura will likely fix the incompatibility with the version of Qt on your system.
ahoeben 1,955
