Hello community,
I would like to understand what and how I specified in the settings to get the result I have. This time I've uploaded a video in youtube, so it can be seen what happens in reality.
I went through the settings that I made but I don't see anything for the fan beside in COOLING (specified at 80%) and in EXPERIMENTAL> BRIDGE FAN SPEED (specified at 99%). In the general settings for "Manage materials" I have 100% fan speed.
Situation:
At layer 15 starts the bridging. The non hanging parts of the layer are printed as it should with the specified settings. Then starts the bridging, which is made to the settings - lower print speed and max fan (not very good result but satisfying for the project).
Layer 16 - starts as specified on non hanging parts. When over the bridging part the print speed is lowered and fan speed goes to 0%!
Layer 17 same as layer 16.
Layer 18 same as layer 16.
Layer 19 same as layer 16.
Layer 20 all parts are at the specified settings.
Why???
Another one thing I've noticed. At the initial - first layer, I normally am tuning manually the fan speed to 0% in order to have better bed bonding. However with this project the stringing in the initial layer was big, so with the last print I tuned the fan speed to 20% manually on the printer. To my surprise when the printing started, the printer corrected the fan speed to 0%!
What am I doing so to have this fan speed changes? How to control them?
Attached are:
- the last settings for the project.
- the gcode.
- the link to the video.
Thank you for your time.
Regards
Stan
stan_bulgaria 4
Attached are the pictures of the finished detail. The filament is transparent and it is difficult to see on picture, but there is severe sagging from one of the sides.
One more thing that I saw on layer 15.
The printing of the openings is in a random order. It starts on the first opening from the middle of the wall towards the center; then the nozzle goes to the second opening and starts from the outer diameter toward the inner side (it starts in the air - it is visible if looking from down up); on the third opening it copies the moves of the first one. After that the print continues again in the air for the first and third openings.
I did not check "Outer before inner walls" box. So what the print order should be - first inner walls and going toward the outer ones or it is a random order?
If the "Outer before inner walls" box is checked the print order is from inner toward the outer diameter of the openings. However on the top layers where the overhangs are at 30 degrees the print starts from outer side which here is in the air!
Regards
Stan
