Actually the gear at the stepper motor was off center, pushing the central gear from place, thus making a gap with the counter gear and then missing contact. Wow.
GregValiant 1,301
Is it repairable or junk? I ask because my current favorite mantra is "Everything is a POS."
I replaced de third party stepper motor gear for yet another, this time a metal one. For now it seems ok. I bought the DDG for a ultimaker 2. Not +. So I had to make some adaptations - a 11 teeth gear (Aliexpress although you can print one) and a spacer adaptor - which I printed.
Edited by my3DBr
my3DBr 4
Hello.
So it seems the bore in the accessory gear is off center, thus giving skips. Anyone with the same problems using Bondtech extruders? Lucky I am...
