My 3D printer (PrimaCreator P120 V3.1) tries to print outside of the printable area
Posted · My 3D printer (PrimaCreator P120 V3.1) tries to print outside of the printable area
Hi everyone!
I'm completely new to the world of 3D printing, and I have come so far as to try and print my first 3D print.
I am trying to print the famous calibration cube, but in the start of every print, my printer nozzle moves to the opposite corner (of the homepoint) and tries to move "out of bounds". I will include a video in this topic. - I have set size settings correctly (that I know of) and I really don't know what this can be. I even checked the starting G-code to see if that was the flaw, but no luck there either.
I am using Ultimaker Cura as my slicer.
Check out the video if you're not sure what the problem is. That will surely explain it!
Thank you in advance.
Sincerely
Jeppe
FullSizeRender.zip
    It may be something as simple as unchecking "Origin at Center" which is on the Manage Printers / Machine Settings page.  If it is already unchecked then:
    Load an STL in Cura.  Set Cura up with your normal settings.  Choose "File | Save Project".  The resultant 3mf file will contain the model, the printer, and all your settings.  Post that here along with that gcode file that is in the video.
    • Thanks 1
    I found out that the machine I have is a "cookie cutter" machine. The same machine is sold with a lot of different brands on it, so I was able to find a YouTube video with some G-code that solved the problem. I also updated the dimenssions of the machine, even though I measured them myself.
    If anyone has the same type of machine as me, even though it's a different brand, you can use this tutorial. After these settings, it printed perfectly.
    Thanks though, Greg! It probably was something with the dimensions of the machine. Because the Gcode I used in the video I uploaded here, was the default code.
    Exactly! I have been printing a lot of stuff. You really get some 3D printing fever after getting it to work the first time!
    It's awesome. This is a machine bought by the school I work on, and now it's time to buy my own!
