Posted
· advice needed - solid abs on extruder assembly
Sorry to see your print head looks like this, but it happens more often than you think. When the object comes loose during the print, then the head moves the object around on the bed and the filament can fill up the head. To prevent this in the future, always check your bed adhesion, especially when someone uses ABS. And also important that the silicon cover in the print head is in a good condition.
You can only use a heat gut to carefully soften the material. Be careful not to soften the rest of the head, but it should work to get out the ABS block.
If you want to try if heating up the print cores is enough, I don't think so, but you can try it, then just press the stop switches by hand in the left back corner, to "fake" the homing. I think the order is important, which of the two switches must be pressed first.
Smithy 1,134
