If anything it's over extruded. I just re-checked the extrusion cal with this roll and same print temp, and it was dead on.
I'm running it again now. Looks ok so far.
I'm not sure what you mean by "Back side", this is the top (last layers printed)
The fuzzy looking parts around the perimeter are excess filament pushed over the cliff.
There's also the spiral pattern which I didn't expect.
The disk is slightly over thick at 5.12 mm.
This is not anything I've hit before.
Snapmaker A350, ABS, 245/95 Filament is in a 55C drybox and then passed through a 90C inline dryer, and the whole path is enclosed in PTFE tube.
Not back side, the top edge of your photo.
Without a file or something to look at (other than a photo) it would just be guessing.
GregValiant 1,330
That looks seriously under-extruded. Use File | Save Project and post the resulting 3mf file here along with that gcode file. What printer is that?
