Overcome by the pla I have tried with a new coil that had a smartfill ASA
I have used the Ultimaker default setting in cura not compatible with my printer, and I have gone down from 255º which was really very hot to 240º
I have added magigoo PA that I had bought for nylon that I also plan to use (and that I don't want to try with PLA in case it gets too hooked on the glass) and at the moment it seems to hook very well.
I have tried without magigoo and it has been impossible for me to hook something on the bed without getting up
I attach two photographs of the first bed that I notice as a kind of projections (it is not detached) that I do not know exactly if they are normal from the second layer everything disappears looking good
I think I have it well calibrated but I don't know if I'm failing in any step, the calibration card can be inserted and removed with some resistance and friction but without getting stuck
Maybe trying this second material can help me a little to find my problem
Thanks
Smithy 1,132
Hi and welcome to the forum!
The normal UHU glue stick is perfect, make a few stripes and then distribute it with a wet towel to get a fine layer of glue.
But even without glue PLA should stick well to the glass. If not, then in 99% of the cases your leveling is not correct and you need to level closer to the glass. I know it from a lot of posts here that many users say, they have leveled the bed many times and it is still not working, but believe me, it is the leveling.
When you level the bed with the included card, I level until I have the feeling the nozzle would scratch the card, but I am still able to pull the card out. So when you move the card should feel some resistance and not just a little bit.
If it still not works, please post a picture of your first layer.
