UlrichC-DE 107
Hello,
I understand this well. Had also sometimes thought at the restart: "what is now?".
In the meantime, I no longer watch. As you know, it only takes longer if you wait for it 🙂
The printer has no recognizable sleep mode, as it is known from monitors and similar devices.
But I have to leave the printer switched on, because I also have a material station.
As soon as I switch it off, it forgets some information about the filament it has loaded.
In addition, I have nylon in the station. This is PA6 material that becomes unusable without dehumidification.
I always leave the printer on for this reason. Except when I am out of the house for days, I turn it off.
Many greetings
UlrichC-DE 107
Hello,
I can assure you that it takes forever until the printer is started.
In normal videos you will never find the startup sequence.
I have a small YT channel myself and I can tell you for sure. A large part of the YT users have patological attention disorders. If you show something so boring, they simply switch. Of course, you don't want to cause that with a video.
Can not make you a video, because I have a bundle. I'm afraid that there the startup takes even longer. (But may well be that I make later still one 😈).
Sometimes it does not start at all. Then I must switch on the printer again.
But it is good that the printer can remain in constant operation. Switching off is not necessarily intended there.
Many greetings
UlrichC-DE 107
Great video 🙂 I could watch it all day long 😉
sotakuma 1
Thank you so much for sharing that, it helps me a lot to feel more secure about the purchase. It surprises me a lot that this is not mention on the manual.
sotakuma 1
-Switching off is not necessarily intended there.- You mean that I can put the printer in some kind of sleep mode?
