Posted (edited) · Cura profiles partially saved
I am having trouble for some time now with profile settings not being saved. I did a clean install of Cura 4.9, deleting all previous versions and profile folder.
I chose a default profile and tweaked at least 50 settings, "Update profile with current settings", chose a name and saved it.
In preference / profiles / global settings the profile shows only 7 saved settings.
Any idea what's up?
Edited by petronel
    Posted · Cura profiles partially saved
    The number of settings displayed in this part is not exactly what is in the profile.  To analyze my profiles I use the Profil Analyser PlugIn to analyze what exactly is saved in a profile and compare the different profils.
    Ie : In cura 7 paramaters
    But in reality There are  20 parameters in this profile
    Thanks a lot! I installed the plugin and i can see now most of the settings there, except the ones unchanged from the profile it's based on. It is possible that my problem in the past was here, where i was changing the base profile and they were automatically transferred to the custom profile. I guess i'll have to add some more profiles and see how it fares.
