thank you for your response, I have done what you suggested with no luck.
Did you get infill wipe distance and the other settings in the link above?
If you follow all the recommendations in the article and it still won't fit then you are out of luck. It looks to me like the issue is in the back right corner where the nozzle changer is - if it prints there it will hit. Maybe if you rotate the part 90 degrees CCW so that the curved part is where the nozzle-changer-keep-away-zone is.
it should be fine. There's a margin of error.
gr5 2,210
set "travel avoid distance" to zero.
disable brim and skirt both
details here:
https://support.ultimaker.com/hc/en-us/articles/360013799339-How-to-print-the-maximum-build-volume-in-Ultimaker-Cura
