foehnsturm 970
I assume a thickness of 0.4 mm should work quite well. If not, two oscillating lines will do it.
It might be visible, depending on wall thickness and material color, like the normal infill.
The curve is an interesting question. I like the idea of having longer segments in touch with the perimeter and peaks facing inwards, like bracings. However the peaks should be printable without any risk due to the sharp corners.
Dim3nsioneer 557
I like the idea. The calculation should not be a problem as long as the layer-to-layer-shape-change is somehow continous. Then it's just a question of curve parametrisation. But three questions popped up:
- Is one layer enough to make it stable?
- Is it visible on the outside of the print (there is such an effect with injection moulding)?
- What is the most suitable type of oscillating curve?
