Posted · Anycubic Chiron leveling
I know this is an old issue, and probably solved, but I have been working with the Anycubic Chiron and CURA for about 7 months.  My problem is the Chiron!  The Chiron has a leveling issue:
Manually leveling all edges of the table to about .003 then checking the center of the table shows the nozzle about .008 higher off the table.  I have had no luck with the auto leveling software provided, so I have been working with parts around the outside of the table to avoid the issue!  I am now looking at a printer that can auto level.  Does anyone know a solution to this issue?  All tables that you put on the Chiron have the same issue (excessive warping)!  Is there a replacement GCode for auto leveling that works?
Thanks
R
    Try cutting a circular piece of tin foil and putting it under the center of the glass.
    My personal fix was to stop checking the center.  I know it's off but for 99% of what I print it's close enough.
