Change print start sequence?
Ch3vr0n
Posted (edited) · Change print start sequence?
Right now when starting a print cura heats up to full print temp, then starts auto levelling, then starts print. This results in loss of filament due to the filament drooping from the nozzle. Is there a way to do it like PrusaSlicer does? Prime nozzle to 120° > start autolevelling sequence > Raise nozzle a little and move nozzle to X-Y home for nozzle prime line > raise temp to desired print temp > print prime line > start print?
That way no filament drooping occurs as the nozzle doesn't reach full temp until AFTER it went through the Autolevelling sequence (BLTouch)
Edited by Ch3vr0n
    Posted · Change print start sequence?
    The commands are in your start gcode.  Something like this would do it.  It is the order of the commands and the use of keywords that are important.
    M104 S120
    M140 S60
    M109 S120
    M190 S60
    G28 X Y
    G29
    M109 S{material_print_temperature_layer_0}
    M190 S{material_bed_temperature_layer_0}
    • 3 weeks later...
    Sorry totally forgot about this cause i didn't get any notifications (despite being subbed). Where do i enter this? Under machine settings. Currently using the default start and end g-code
    Quote
    [start]
    M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
    M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
    M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
    M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
    M220 S100 ;Reset Feedrate
    M221 S100 ;Reset Flowrate
    G28 ;Home
    G29 ;Auto bed Level
    G92 E0 ;Reset Extruder
    G1 Z2.0 F3000 ;Move Z Axis up
    G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
    G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
    G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
    G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
    Quote
    [end]
    G91 ;Relative positioning
    G1 E-2 F2700 ;Retract a bit
    G1 E-2 Z0.2 F2400 ;Retract and raise Z
    G1 X5 Y5 F3000 ;Wipe out
    G1 Z10 ;Raise Z more
    G90 ;Absolute positioning
    G1 X0 Y{machine_depth} ;Present print
    M106 S0 ;Turn-off fan
    M104 S0 ;Turn-off hotend
    M140 S0 ;Turn-off bed
    M84 X Y E ;Disable all steppers but Z
    while doing some research, shouldn't M109 (wait for hotend temperature) be used in combo with M104 (set hotend temperature), i can read but understanding things is a different matter
    Edited by Ch3vr0n
