Hmm I might have to. I also found out I can't print without a second print core inserted, so the printer is completely down and out now...
I tried a factory reset also, and no luck. So it's still stuck.
you could try to clean the printcore-contacts of the printhead with a cotton swab and alcohol and perhaps reseat the plug of the printhead cable. Possibly it's just a contact problem and no circuit damage.
Regards
I tried cleaning all the contacts, old cores and on the board, and no change unfortunately. I can look at restarting the plug too.
Smithy 1,145
Contact 3DSolex, it seems the Solex print core has damaged your print head board due to some contact problems.
