Cura on Federa 34
kyiu
Posted · Cura on Federa 34
I'm new to 3D printing. I'm running the latest Cura slicer on my Linux box. The software runs perfectly and simulating the printing correctly at the middle of the bed. But, when I loaded the model into my printer (Creality CR-10S PRO V2), the printer started to print at the corner instead of at the middle of the bed. I'm sure is the software configuration problem. How to I tell my printer to do the printing...
    Go to left side of screen in PREPARE mode.  Click on your printer, then do "manage printers" then "machine settings", Uncheck "origin at center".  Also check the dimensions of your bed - for example, if it says your bed is 100mm wide but it is actually 200mm wide then it will be printing on the left half of your print bed.
