The Z axis is stuck or the limit switch is broken - ER16
Posted
· The Z axis is stuck or the limit switch is broken - ER16
If you go to System -> Maintenance -> Diagnostics -> Limit switches, does the indicator for the Z-switch get an "X" in it? And does it go away when you manually grab the platform and pull it up?
If not, you're either dealing with a broken switch, a bad solder joint of the wires attached to the switch itself or a bad connection to the mainboard. If you have access to a multimeter you can probe the connector for continuity and see if it gets continuity when the switch is pressed, that would verify that the switch is physically ok or not.
IRobertI 521
